Продам Cisco WS-C3550-12G с ушами (самая низкая цена)
S-C3550-12G с ушами - 1800 грн
в отличном состоянии (ничего не отломано, не погнуто).
Відредаговано None
Base ethernet MAC Address: 00:0f:f7:0d:41:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 159 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 16128000
flashfs[0]: Bytes used: 14926848
flashfs[0]: Bytes available: 1201152
flashfs[0]: flashfs fsck took 18 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Loading "flash:/c3550-i5q3l2-mz.121-22.EA1a/c3550-i5q3l2-mz.121-22.EA1a.bin"...#
File "flash:/c3550-i5q3l2-mz.121-22.EA1a/c3550-i5q3l2-mz.121-22.EA1a.bin" uncomp
ressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(22)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 20-Aug-04 00:44 by yenanh
Image text-base: 0x00003000, data-base: 0x0083AF00
Initializing flashfs...
flashfs[1]: 159 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 16128000
flashfs[1]: Bytes used: 14926848
flashfs[1]: Bytes available: 1201152
flashfs[1]: flashfs fsck took 11 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
cisco WS-C3550-12G (PowerPC) processor (revision H0) with 65526K/8192K bytes of
memory.
Processor board ID CAT0815Z0XY
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 2 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 7 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 8 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 9 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 10 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 11 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 12 has 1 Gigabit Ethernet/IEEE 802.3 interface
12 Gigabit Ethernet/IEEE 802.3 interface(s)
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:F7:0D:41:00
Motherboard assembly number: 73-5526-08
Power supply part number: 34-0967-01
Motherboard serial number: CAT081403L7
Power supply serial number: LIT08060BU2
Model revision number: H0
Motherboard revision number: A0
Model number: WS-C3550-12G
System serial number: CAT0815Z0XY
Press RETURN to get started!
00:01:17: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:19: %SYS-5-CONFIG_I: Configured from memory by console
00:01:20: %SYS-5-RESTART: System restarted --
(fc1)
00:01:20: %SNMP-5-COLDSTART: SNMP agent on host Switch is undergoing a cold star
t
Switch>
Демпингатор ... Че на новую печень не хватает ? То суммит за 1000 бакинских комиссаров то сиськи в ноль :)
В наличии 5 шт с ушами в отличном состоянии (ничего не отломано, не погнуто) - полностью рабочие.
Цена 1800 грн / шт
Відредаговано None
Ладна... 1700 грн / шт с ушами в отличном состоянии, полностью рабочие. В наличии 5 шт.
Для справки: GBIC WDM с одного конца и SFP WDM с другого 100% совместимы: http://forum.nag.ru/forum/index.php?showtopic=61260
Обновил прошивки до свежей версии IOS:
Switch>show ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(55)SE7,
RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 11:46 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01606C54
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 1 minute
System returned to ROM by power-on
System image file is "flash:c3550-ipservicesk9-mz.122-55.SE7/c3550-ipservicesk9-
mz.122-55.SE7.bin"
Відредаговано None
Распродажа! В наличии 9 шт - цена 1400 грн / шт - полностью рабочие! в отличном состоянии!
Уши +85 грн. Консольный кабель cisco (новый запечатан) +15 грн.
Отличная цена для агрегации! Покрывает стоимость Gbic WDM.
Gbic с одного конца - совместимы с SFP с другого!
Не вижу смысла наживаться на сетевиках... лишь бы единый налог, бензин, скотч и хавка покрывались  :facepalm:
Відредаговано None
Да ты святой ! Слушай друг , мне тут кайлом помахать нужно так и быть цитирую - единый налог , харч ну и это бензин доставлю так сказать :) . Согласен ?  Я думаю вы даже в большем приваре будете , чем от продажи коммутаторов :).
Тем временем "минус" одна сабжевая кошка.... осталось 8 шт в отличном состоянии.
Осталось 7 шт...  цена 1400 грн / шт - полностью рабочие! в отличном состоянии!
Gbic с одного конца - совместимы с SFP с другого! http://forum.nag.ru/forum/index.php?showtopic=61260
Познавательное видео о том, что представляют из себя GBIC-модули и как они вставляются в коммутатор:
1250 грн / шт. В наличии 7 шт. Уши +85 грн, запечатанный консольный кабель Cisco +15 грн.
Layer 3. Бордер BGP влазит вся Украина.
Появились. Up
1100 грн / шт
уши +85 грн
консольный кабель cisco новый в упаковке +15 грн
Відредаговано None
  • 5 weeks later...
В наличии 2 шт полностью рабочие в отличном состояни - 1400 грн. Уши +85 грн. Консольный кабель новый запечатанный +15 грн.
Отличное состояние, ничего не отломано и не погнуто, полностью рабочий, залит последний полный firmware "c3750-ipserviceslmk9-tar.122-55.SE8.bin"
1100 грн
999 грн - сверхнизкая цена. Последняя полная прошивка за июнь 2013: c3550-ipservicesk9-mz.122-55.se8.bin
Відредаговано None
    • Від yurii11
      пишите
    • Від gus
      Продаж
      Комутатори:
      Cisco SG100-24-24   1900грн
      Cisco Catalyst 2960-x 48 (WS-C2960X-48TS-L) 2600грн
      Cisco Catalyst 2960-x 24 (WS-C2960-24TT-L) 1300грн
      Cisco Catalyst 3650 24 2x10G (WS-C3650-24TD) 6000грн
      D-Link DGS-3120-48TS - 5000грн
      D-Link DGS-3100-48 - 4500грн
      Маршрутизатор
      Cisco 1941 Series 1500грн
      Фаєрвол
      Cisco ASA5515-X 4000грн
      8 портовий KVM перемикач Master view ATEN SC-88A 900грн
      Гарантія на перевірку
      068-897-37-56
    • Від Михаил Гордиенко
      Продам Комутатор світч Cisco Nexus 2348TQ 10GE. Привезли з Європи. з'ясувалось, що мені він не потрібен, немає де використати. Ціна для форума 250$ Кому потрібен - запитуйте, торгуємо.
    • Від olapchuk
      Вечір добрий
      як влан створити, видалити і переімінувати розібрався через snmp, якщо комусь цікаво тут написано https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/45080-vlans.html, якщо треба приклади скину
      але проблема в наступному, в ціско всі знають є таке штука яка interface vlan **id**
      interface Vlan3**
        no shutdown
        ip address 192.168.***.***/27
    • Від Pavlo_110
      Продам маршрутизатори cisco asr 1004 в робочому стані. 2 шт. Ціна 5000 $ за 2 шт.. Пропозиції пишіть в особисті повідомдення. Продаємо по причині переходу на інший вендор.
