Переадресация из NAS
Добрый день всем.
Есть 2 сервера один биллинг второй nas(rscriptd), так вот когда у клиента(на nas) деньги есть все работает замечательно, как только уходит  в минус не работает переадресация должников при это на биллинге все пашет как часы, в чем проблема?
firewall.conf(billng)
#!/bin/sh
# firewall command
FwCMD="/sbin/ipfw -q"
${FwCMD} -f flush
# Interfaces setup
LAN_IF="re2"
WAN_IF="re0"
# Networks define
${FwCMD} table 2 add 172.16.0.0/20
#NAT
${FwCMD} nat 1 config log if ${WAN_IF} reset same_ports
${FwCMD} add 6000 nat 1 ip from table\(2\) to not table\(9\) out xmit ${WAN_IF}
${FwCMD} add 6001 nat 1 ip from any to me in recv ${WAN_IF}
#Shaper - table 4 download speed, table 3 - upload speed
${FwCMD} add 12001 pipe tablearg ip from any to table\(4\) via ${LAN_IF} out
${FwCMD} add 12000 pipe tablearg ip from table\(3\) to any via ${LAN_IF} in
# default block policy
${FwCMD} add 65533 deny all from table\(2\) to any via ${LAN_IF}
${FwCMD} add 65534 deny all from any to table\(2\) via ${LAN_IF}
${FwCMD} add 65535 allow all from any to any
#Debtors forwarding
${FwCMD} add 4 allow ip from table\(2\) to 8.8.8.8 dst-port 53 via ${LAN_IF}
${FwCMD} add 4 allow ip from 8.8.8.8 to table\(2\) src-port 53 via ${LAN_IF}
${FwCMD} add 4 allow ip from table\(2\) to me dst-port 80 via ${LAN_IF}
${FwCMD} add 4 allow ip from me to table\(2\) src-port 80 via ${LAN_IF}
${FwCMD} add 6 fwd 127.0.0.1,80 ip from table\(47\) to not me dst-port 80
${FwCMD} delete 65534
#Unknow user redirect
${FwCMD} add 5 fwd 127.0.0.1,80 ip from 172.32.0.0/20 to not me dst-port 80
${FwCMD} add 8 allow ip from 172.32.0.0/20 to 8.8.8.8 dst-port 53 via ${LAN_IF}
${FwCMD} add 8 allow ip from 8.8.8.8 to 172.32.0.0/20 src-port 53 via ${LAN_IF}
firewall.conf(nas)
#!/bin/sh
# netflow stats
/usr/local/sbin/softflowd -i sk0 -n 192.168.56.90:42111
# firewall command
${FwCMD} -f flush
# Networks define
${FwCMD} table 2 add 172.16.0.0/21
${FwCMD} table 9 add 172.16.0.0/21
${FwCMD} table 9 add 192.168.0.73/32
#NAT
${FwCMD} nat 1 config log if re1 reset same_ports
${FwCMD} add 6000 nat 1 ip from table\(2\) to not table\(9\) via re1
${FwCMD} add 6001 nat 1 ip from any to 192.168.0.73 via re1
# in 6001 rule must be my external IP
#Shape
${FwCMD} add 12001 pipe tablearg ip from any to table\(4\) via sk0 out
${FwCMD} add 12000 pipe tablearg ip from table\(3\) to any via sk0 in
#security
${FwCMD} add 3 deny ip6 from any to any
${FwCMD} add 101 allow all from 192.168.56.90 to any
${FwCMD} add 101 allow all from any to 192.168.56.90
${FwCMD} add 101 allow all from 172.16.0.1 to any
${FwCMD} add 101 allow all from any to 172.16.0.1
# allow access to my http for all
${FwCMD} add 62000 allow tcp from any to me dst-port 80
${FwCMD} add 62000 allow tcp from me to any src-port 80
${FwCMD} add 65533 deny all from table\(2\) to any via sk0
${FwCMD} add 65534 deny all from any to table\(2\) via sk0
# ==== CUSTOM FIREWALL CONFIG ====
${FwCMD} add 62100 allow tcp from table\(2\) to table\(17\) dst-port 80
${FwCMD} add 62100 allow tcp from table\(17\) to table\(2\) src-port 80
1. А где редиректы на насе?
2 Зачем /usr/local/sbin/softflowd -i sk0 -n 192.168.56.90:42111 в firewall.conf?
Відредаговано jcomm
добавил редирект но все равно не работает.
${FwCMD} add 4 allow ip from table\(2\) to 8.8.8.8 dst-port 53 via sk0
${FwCMD} add 4 allow ip from 8.8.8.8 to table\(2\) src-port 53 via sk0
${FwCMD} add 4 allow ip from table\(2\) to me dst-port 80 via sk0
${FwCMD} add 4 allow ip from me to table\(2\) src-port 80 via sk0
${FwCMD} add 6 fwd 172.16.0.1,80 ip from table\(47\) to not me dst-port 80
2) даже не задумывался об этом.
а почему "to not me"? По идее должно быть "to not my.billing.server.ip"...
При каждом ресете фаервола софтфлоуд слушает на интерфейсе. Но... никогда вы не отключаете его
Відредаговано jcomm
  • 11 months later...
Всем Доброго времени суток! Аналогичная ситуация (Биллинг+NAS и удаленный rscriptd) все делал по инструкции. Абоненты что висят на Биллинг+NAS ходят в кабинет пользователя при любом балансе, те которые на rscriptd при плюсовом заходить могут, при минусе видят 404 not found nginx/1.6.2
fwd может работать только на 127.0.0.1
дальше ставить апач\nginx и на них делать редирект на нужную ссылку.
Неделю голову ломаю где ставить апач\nginx и как в точности должен выглядеть редирект. Перепробовал массу вариантов - безуспешно.
С Freebsd дружу не долго, очень надеюсь подружится получше. Заранее благодарю за любые ответы.
Биллинг+NAS freebsd10.2
NAS-rscriptd freebsd 9.3
root@NAS: /etc/rc.conf
hostname="nas.isp"
ntpdate_enable="YES"
ifconfig_bge0="inet 172.16.1.1 netmask 255.255.248.0"
ifconfig_bge0_alias0="inet 172.32.1.1 netmask 255.255.255.0"
ifconfig_bge0_alias1="inet 172.16.2.1 netmask 255.255.255.0"
ifconfig_bge1="inet 172.244.127.98 netmask 255.255.255.0"
ifconfig_bge2="inet 192.168.56.94 netmask 255.255.255.0"
defaultrouter="172.244.127.100"
sshd_enable="YES"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="AUTO"
# NAS custom
firewall_enable="YES"
firewall_nat_enable="YES"
dummynet_enable="YES"
firewall_script="/etc/firewall.conf"
thttpd_enable="YES"
snmpd_enable="YES"
snmpd_flags="-a"
snmpd_conffile="/usr/local/etc/snmpd.config"
nginx_enable="YES"
root@NAS: /etc/firewall.conf
#!/bin/sh
# netflow stats
/usr/local/sbin/softflowd -i bge0 -n 192.168.56.93:42111
# firewall command
${FwCMD} -f flush
# Networks define
${FwCMD} table 9 add 172.244.127.98/32
#NAT
${FwCMD} nat 1 config log if bge1 reset same_ports
${FwCMD} add 6000 nat 1 ip from table\(2\) to not table\(9\) via bge1
${FwCMD} add 6001 nat 1 ip from any to 172.244.127.98 via bge1
#Shape
${FwCMD} add 12001 pipe tablearg ip from any to table\(4\) via bge0 out
${FwCMD} add 12000 pipe tablearg ip from table\(3\) to any via bge0 in
#security
${FwCMD} add 101 allow all from 192.168.56.93 to any
${FwCMD} add 101 allow all from any to 192.168.56.93
${FwCMD} add 65533 deny all from table\(2\) to any via bge0
${FwCMD} add 65534 deny all from any to table\(2\) via bge0
#Debtors forwarding
${FwCMD} add 4 allow ip from table\(2\) to 8.8.8.8 dst-port 53 via bge0
${FwCMD} add 4 allow ip from 8.8.8.8 to table\(2\) src-port 53 via bge0
${FwCMD} add 4 allow ip from table\(2\) to me dst-port 80 via bge0
${FwCMD} add 4 allow ip from me to table\(2\) src-port 80 via bge0
hostname="nas.isp"
sshd_enable="YES"
dumpdev="AUTO"
# NAS custom
thttpd_enable="YES"
snmpd_enable="YES"
snmpd_flags="-a"
nginx_enable="YES"
#!/bin/sh
# netflow stats
# firewall command
${FwCMD} -f flush
# Networks define
#NAT
#Shape
#security
#Debtors forwarding
а через какой интерфейс они у вас должны бегать в каьинет когда фаервол им блокирует выход за нас ...???? bge2="inet 192.168.56.94 netmask 255.255.255.0"   это у вас куда смотрит ???  ifconfig_bge0="inet 172.16.1.1 netmask 255.255.248.0"
а енто походу локалка пользователей ??
как у вас UHW работает на насе ???
ifconfig_bge0="inet 172.16.1.1 netmask 255.255.248.0" - абоненты
ifconfig_bge0_alias0="inet 172.32.1.1 netmask 255.255.255.0" - свичи (management)
ifconfig_bge0_alias1="inet 172.16.2.1 netmask 255.255.255.0" - абоненты
ifconfig_bge1="inet 172.244.127.98 netmask 255.255.255.0" - внешний интерфейс (за ним находится роутер который смотрит в inet на этот же роутер смотрит внешний интерфейс Биллинг+NAS
ifconfig_bge2="inet 192.168.56.94 netmask 255.255.255.0"   - этот для общения с Биллинг+NAS
На всякий случай вот конфиг Биллинг+NAS  в сети 172.16.0.1 все работает как надо, не выходят в кабинет 172.16.1.1 и 172.16.2.1
root@ubilling: cat /etc/rc.conf
hostname="ubilling"
ifconfig_bge0="inet 172.16.0.1/21"
ifconfig_bge0_alias0="inet 172.32.0.1 netmask 255.255.240.0"
ifconfig_bge0_alias1="inet 172.32.1.2 netmask 255.255.255.0"
ifconfig_bge1="inet 172.244.127.97 netmask 255.255.255.0"
ifconfig_nfe0="inet 192.168.56.93 netmask 255.255.255.0"
sshd_enable="YES"
dumpdev="AUTO"
# ====== added by UBinstaller ====
#all needed services
mysql_enable="YES"
apache24_enable="YES"
dhcpd_enable="YES"
dhcpd_flags="-q"
dhcpd_conf="/usr/local/etc/multinet/dhcpd.conf"
dhcpd_ifaces="bge0"
ubilling_enable="YES"
ubilling_flags="bge0"
#optional services
memcached_enable="NO"
memcached_flags="-l 127.0.0.1 -m 64"
radiusd_enable="NO"
#access/shape/nat
root@ubilling: /etc/firewall.conf
#!/bin/sh
# firewall command
${FwCMD} -f flush
# Interfaces setup
LAN_IF="bge0"
WAN_IF="bge1"
# Networks define
# Unknown users redirect
#NAT
#Debtors forwarding
${FwCMD} add 4 allow ip from table\(2\) to 193.41.60.8 dst-port 53 via bge0
${FwCMD} add 4 allow ip from 193.41.60.8 to table\(2\) src-port 53 via bge0
В кабинет ходят по ip 172.244.127.97
правильно ентот адресс находится за фаерволом НАСА .... и его абоны не видят когда их отключает .... ))
а тут о чем билинг с насом разговаривают ???
так .... вам нужен либо тунель с локалки биллинга в локалку наса либо вызывать шамана ВУДУ шоб тот пакеты абонов проводил через нас фаервол ))
MYSQL, Stargazer  все как на видео там по 3 интерфейса на обеих агрегатах.
у вас на убилле одна сетевая смотрит на роутер и получает на него мир .... вторая смотрит в сторону абонов биллинга ... и третья смотрит в третью НАСА ....???
аааа    видео  ....))   третий походу нужен для администрирования убилла ..)) шоб не дай бог абоны биллинг увидят и будут себе денег добавлять ..))
Так и есть.
Блокирование - политика по умолчанию для подсети пользователей через внутренний интерфейс. Проявите осторожность. Если вы планируете доступ к биллингу для администрирования из внутренней сети - поправьте перед перезагрузкой /etc/firewall.conf (да да - это во второй раз)
вот енто из манов
Відредаговано seversever404
Так и есть.
круто .... да так правильно ....  теперь осталось придумать как абоны будут видеть кабинет который доступен ток за НАСОМ
как вы это представляете ... ???
и может вас заинтересует такая штука как UHW ... клевая штука ...)) ... облегчает работу админа
Видимо необходимо прописать проброс портов в firewall.conf из локалки на адрес 172.244.127.97 на котором К/П доступен всегда, возможно не только в firewall а еще и сюда.
${FwCMD} add 6 fwd 172.16.0.1,80 ip from table\(47\) to not me dst-port 80 а почему "to not me"? По идее должно быть "to not my.billing.server.ip".
вот ещё что то интересное ))
не думаю что енто понадобится
    • Від ProstoName
    • Від ppv
    • Від camchatix
      Привіт!
    • Від camchatix
      Добрий день,
    • Від grach_witch_cheese
      Вітаю, колеги!
      Маю наступну схему:
      Питання:
