Debian файловая система доступна только для чтения
fet4
Приветствую!
Подскажите сыпет вот такое в лог и система доступна только для чтения. Я так понял мрет диск, ssd стоит?
Feb 10 11:05:08 srv-bill kernel: [  549.009768] ata2.00: exception Emask 0x10 SAct 0x700 SErr 0x400100 action 0x6 frozen
Feb 10 11:05:08 srv-bill kernel: [  549.009796] ata2.00: irq_stat 0x08000000, interface fatal error
Feb 10 11:05:08 srv-bill kernel: [  549.009812] ata2: SError: { UnrecovData Handshk }
Feb 10 11:05:08 srv-bill kernel: [  549.009827] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.009844] ata2.00: cmd 61/40:40:00:d8:52/05:00:00:00:00/40 tag 8 ncq 688128 out
Feb 10 11:05:08 srv-bill kernel: [  549.009844]          res 40/00:50:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.009882] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.009893] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.009917] ata2.00: cmd 61/40:48:40:dd:52/05:00:00:00:00/40 tag 9 ncq 688128 out
Feb 10 11:05:08 srv-bill kernel: [  549.009917]          res 40/00:50:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.009957] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.009969] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.009984] ata2.00: cmd 61/80:50:80:e2:52/05:00:00:00:00/40 tag 10 ncq 720896 out
Feb 10 11:05:08 srv-bill kernel: [  549.009984]          res 40/00:50:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.010032] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.010045] ata2: hard resetting link
Feb 10 11:05:08 srv-bill kernel: [  549.333504] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
Feb 10 11:05:08 srv-bill kernel: [  549.344451] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:08 srv-bill kernel: [  549.344468] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:08 srv-bill kernel: [  549.364345] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:08 srv-bill kernel: [  549.364349] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:08 srv-bill kernel: [  549.374424] ata2.00: configured for UDMA/133
Feb 10 11:05:08 srv-bill kernel: [  549.374446] ata2: EH complete
Feb 10 11:05:08 srv-bill kernel: [  549.381458] ata2.00: exception Emask 0x10 SAct 0x3800 SErr 0x400100 action 0x6 frozen
Feb 10 11:05:08 srv-bill kernel: [  549.381484] ata2.00: irq_stat 0x08000000, interface fatal error
Feb 10 11:05:08 srv-bill kernel: [  549.382155] ata2: SError: { UnrecovData Handshk }
Feb 10 11:05:08 srv-bill kernel: [  549.382830] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.383504] ata2.00: cmd 61/80:58:80:e2:52/05:00:00:00:00/40 tag 11 ncq 720896 out
Feb 10 11:05:08 srv-bill kernel: [  549.383504]          res 40/00:68:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.384843] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.385520] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.386238] ata2.00: cmd 61/40:60:40:dd:52/05:00:00:00:00/40 tag 12 ncq 688128 out
Feb 10 11:05:08 srv-bill kernel: [  549.386238]          res 40/00:68:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.387582] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.388249] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:08 srv-bill kernel: [  549.388934] ata2.00: cmd 61/40:68:00:d8:52/05:00:00:00:00/40 tag 13 ncq 688128 out
Feb 10 11:05:08 srv-bill kernel: [  549.388934]          res 40/00:68:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:08 srv-bill kernel: [  549.390268] ata2.00: status: { DRDY }
Feb 10 11:05:08 srv-bill kernel: [  549.390959] ata2: hard resetting link
Feb 10 11:05:08 srv-bill kernel: [  549.709195] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
Feb 10 11:05:08 srv-bill kernel: [  549.720088] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:08 srv-bill kernel: [  549.720093] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:08 srv-bill kernel: [  549.740031] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:08 srv-bill kernel: [  549.740035] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:09 srv-bill kernel: [  549.750094] ata2.00: configured for UDMA/133
Feb 10 11:05:09 srv-bill kernel: [  549.750115] ata2: EH complete
Feb 10 11:05:09 srv-bill kernel: [  549.757177] ata2.00: exception Emask 0x10 SAct 0x1c000 SErr 0x400100 action 0x6 frozen
Feb 10 11:05:09 srv-bill kernel: [  549.757928] ata2.00: irq_stat 0x08000000, interface fatal error
Feb 10 11:05:09 srv-bill kernel: [  549.758665] ata2: SError: { UnrecovData Handshk }
Feb 10 11:05:09 srv-bill kernel: [  549.759403] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  549.760148] ata2.00: cmd 61/40:70:00:d8:52/05:00:00:00:00/40 tag 14 ncq 688128 out
Feb 10 11:05:09 srv-bill kernel: [  549.760148]          res 40/00:80:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  549.761810] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  549.762609] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  549.763399] ata2.00: cmd 61/40:78:40:dd:52/05:00:00:00:00/40 tag 15 ncq 688128 out
Feb 10 11:05:09 srv-bill kernel: [  549.763399]          res 40/00:80:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  549.764931] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  549.765663] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  549.766402] ata2.00: cmd 61/80:80:80:e2:52/05:00:00:00:00/40 tag 16 ncq 720896 out
Feb 10 11:05:09 srv-bill kernel: [  549.766402]          res 40/00:80:80:e2:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  549.767760] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  549.768495] ata2: hard resetting link
Feb 10 11:05:09 srv-bill kernel: [  550.084889] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
Feb 10 11:05:09 srv-bill kernel: [  550.095786] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:09 srv-bill kernel: [  550.095792] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:09 srv-bill kernel: [  550.115742] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:09 srv-bill kernel: [  550.115747] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:09 srv-bill kernel: [  550.125761] ata2.00: configured for UDMA/133
Feb 10 11:05:09 srv-bill kernel: [  550.125774] ata2: EH complete
Feb 10 11:05:09 srv-bill kernel: [  550.132849] ata2: limiting SATA link speed to 1.5 Gbps
Feb 10 11:05:09 srv-bill kernel: [  550.132853] ata2.00: exception Emask 0x10 SAct 0xe0000 SErr 0x400100 action 0x6 frozen
Feb 10 11:05:09 srv-bill kernel: [  550.133572] ata2.00: irq_stat 0x08000000, interface fatal error
Feb 10 11:05:09 srv-bill kernel: [  550.134256] ata2: SError: { UnrecovData Handshk }
Feb 10 11:05:09 srv-bill kernel: [  550.134919] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  550.135585] ata2.00: cmd 61/80:88:80:e2:52/05:00:00:00:00/40 tag 17 ncq 720896 out
Feb 10 11:05:09 srv-bill kernel: [  550.135585]          res 40/00:98:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  550.136969] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  550.137743] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  550.138420] ata2.00: cmd 61/40:90:40:dd:52/05:00:00:00:00/40 tag 18 ncq 688128 out
Feb 10 11:05:09 srv-bill kernel: [  550.138420]          res 40/00:98:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  550.139801] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  550.140470] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 10 11:05:09 srv-bill kernel: [  550.141157] ata2.00: cmd 61/40:98:00:d8:52/05:00:00:00:00/40 tag 19 ncq 688128 out
Feb 10 11:05:09 srv-bill kernel: [  550.141157]          res 40/00:98:00:d8:52/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Feb 10 11:05:09 srv-bill kernel: [  550.142566] ata2.00: status: { DRDY }
Feb 10 11:05:09 srv-bill kernel: [  550.143236] ata2: hard resetting link
Feb 10 11:05:11 srv-bill kernel: [  552.355021] ata2: SATA link down (SStatus 1 SControl 310)
Feb 10 11:05:11 srv-bill kernel: [  552.373873] ata2: hard resetting link
Feb 10 11:05:13 srv-bill kernel: [  554.585189] ata2: SATA link down (SStatus 1 SControl 310)
Feb 10 11:05:13 srv-bill kernel: [  554.592077] ata2: hard resetting link
Feb 10 11:05:16 srv-bill kernel: [  556.803367] ata2: SATA link down (SStatus 1 SControl 310)
Feb 10 11:05:16 srv-bill kernel: [  556.803374] ata2.00: disabled
Feb 10 11:05:16 srv-bill kernel: [  556.811354] ata2: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t4
Feb 10 11:05:16 srv-bill kernel: [  556.812812] ata2: irq_stat 0x00000040, connection status changed
Feb 10 11:05:16 srv-bill kernel: [  556.813762] ata2: SError: { CommWake DevExch }
Feb 10 11:05:16 srv-bill kernel: [  556.814813] ata2: hard resetting link
Feb 10 11:05:16 srv-bill kernel: [  557.534767] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Feb 10 11:05:16 srv-bill kernel: [  557.545661] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:16 srv-bill kernel: [  557.545665] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:16 srv-bill kernel: [  557.549309] ata2.00: ATA-9: INTEL SSDSC2BW120A4, DC32, max UDMA/133
Feb 10 11:05:16 srv-bill kernel: [  557.549311] ata2.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Feb 10 11:05:16 srv-bill kernel: [  557.565604] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20140926/psargs-359)
Feb 10 11:05:16 srv-bill kernel: [  557.565608] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node ffff88011e8442c0), AE_NOT_FOUND (20140926/psparse-536)
Feb 10 11:05:16 srv-bill kernel: [  557.575636] ata2.00: configured for UDMA/133
Feb 10 11:05:16 srv-bill kernel: [  557.575649] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.575651] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 10 11:05:16 srv-bill kernel: [  557.575652] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.575653] Sense Key : Aborted Command [current] [descriptor]
Feb 10 11:05:16 srv-bill kernel: [  557.575655] Descriptor sense data with sense descriptors (in hex):
Feb 10 11:05:16 srv-bill kernel: [  557.575656]         72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Feb 10 11:05:16 srv-bill kernel: [  557.575662]         00 52 d8 00
Feb 10 11:05:16 srv-bill kernel: [  557.575664] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.575666] Add. Sense: No additional sense information
Feb 10 11:05:16 srv-bill kernel: [  557.575667] sd 1:0:0:0: [sda] CDB:
Feb 10 11:05:16 srv-bill kernel: [  557.575669] Write(10): 2a 00 00 52 e2 80 00 05 80 00
Feb 10 11:05:16 srv-bill kernel: [  557.575674] blk_update_request: I/O error, dev sda, sector 5431936
Feb 10 11:05:16 srv-bill kernel: [  557.576678] EXT4-fs warning (device dm-0): ext4_end_bio:317: I/O error -5 writing to inode 6424068 (offset 0 size 0 starting block 191056)
Feb 10 11:05:16 srv-bill kernel: [  557.576681] Buffer I/O error on device dm-0, logical block 191056
Feb 10 11:05:16 srv-bill kernel: [  557.577988] Buffer I/O error on device dm-0, logical block 191057
Feb 10 11:05:16 srv-bill kernel: [  557.579142] Buffer I/O error on device dm-0, logical block 191058
Feb 10 11:05:16 srv-bill kernel: [  557.580015] Buffer I/O error on device dm-0, logical block 191059
Feb 10 11:05:16 srv-bill kernel: [  557.580667] Buffer I/O error on device dm-0, logical block 191060
Feb 10 11:05:16 srv-bill kernel: [  557.581303] Buffer I/O error on device dm-0, logical block 191061
Feb 10 11:05:16 srv-bill kernel: [  557.581943] Buffer I/O error on device dm-0, logical block 191062
Feb 10 11:05:16 srv-bill kernel: [  557.582604] Buffer I/O error on device dm-0, logical block 191063
Feb 10 11:05:16 srv-bill kernel: [  557.583277] Buffer I/O error on device dm-0, logical block 191064
Feb 10 11:05:16 srv-bill kernel: [  557.583928] Buffer I/O error on device dm-0, logical block 191065
Feb 10 11:05:16 srv-bill kernel: [  557.584562] EXT4-fs warning (device dm-0): ext4_end_bio:317: I/O error -5 writing to inode 6424068 (offset 0 size 0 starting block 191224)
Feb 10 11:05:16 srv-bill kernel: [  557.584572] sd 1:0:0:0: rejecting I/O to offline device
Feb 10 11:05:16 srv-bill kernel: [  557.585164] sd 1:0:0:0: [sda] killing request
Feb 10 11:05:16 srv-bill kernel: [  557.585173] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585174] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 10 11:05:16 srv-bill kernel: [  557.585175] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585175] Sense Key : Aborted Command [current] [descriptor]
Feb 10 11:05:16 srv-bill kernel: [  557.585176] Descriptor sense data with sense descriptors (in hex):
Feb 10 11:05:16 srv-bill kernel: [  557.585177]         72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Feb 10 11:05:16 srv-bill kernel: [  557.585181]         00 52 d8 00
Feb 10 11:05:16 srv-bill kernel: [  557.585182] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585183] Add. Sense: No additional sense information
Feb 10 11:05:16 srv-bill kernel: [  557.585184] sd 1:0:0:0: [sda] CDB:
Feb 10 11:05:16 srv-bill kernel: [  557.585185] Write(10): 2a 00 00 52 dd 40 00 05 40 00
Feb 10 11:05:16 srv-bill kernel: [  557.585188] blk_update_request: I/O error, dev sda, sector 5430592
Feb 10 11:05:16 srv-bill kernel: [  557.585775] EXT4-fs warning (device dm-0): ext4_end_bio:317: I/O error -5 writing to inode 6424068 (offset 0 size 0 starting block 190888)
Feb 10 11:05:16 srv-bill kernel: [  557.585818] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585819] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 10 11:05:16 srv-bill kernel: [  557.585820] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585820] Sense Key : Aborted Command [current] [descriptor]
Feb 10 11:05:16 srv-bill kernel: [  557.585821] Descriptor sense data with sense descriptors (in hex):
Feb 10 11:05:16 srv-bill kernel: [  557.585822]         72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Feb 10 11:05:16 srv-bill kernel: [  557.585825]         00 52 d8 00
Feb 10 11:05:16 srv-bill kernel: [  557.585827] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.585828] Add. Sense: No additional sense information
Feb 10 11:05:16 srv-bill kernel: [  557.585828] sd 1:0:0:0: [sda] CDB:
Feb 10 11:05:16 srv-bill kernel: [  557.585829] Write(10): 2a 00 00 52 d8 00 00 05 40 00
Feb 10 11:05:16 srv-bill kernel: [  557.585832] blk_update_request: I/O error, dev sda, sector 5429248
Feb 10 11:05:16 srv-bill kernel: [  557.586414] EXT4-fs warning (device dm-0): ext4_end_bio:317: I/O error -5 writing to inode 6424068 (offset 0 size 0 starting block 190720)
Feb 10 11:05:16 srv-bill kernel: [  557.586496] ata2: EH complete
Feb 10 11:05:16 srv-bill kernel: [  557.586509] sd 1:0:0:0: [sda]
Feb 10 11:05:16 srv-bill kernel: [  557.586510] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Feb 10 11:05:16 srv-bill kernel: [  557.586512] sd 1:0:0:0: [sda] CDB:
Feb 10 11:05:16 srv-bill kernel: [  557.586513] Write(10): 2a 00 07 02 e2 98 00 00 b0 00
Feb 10 11:05:16 srv-bill kernel: [  557.586517] blk_update_request: I/O error, dev sda, sector 117629592
Feb 10 11:05:16 srv-bill kernel: [  557.587123] sd 1:0:0:0: rejecting I/O to offline device
1. Скачать бекапы на другой таз.
2. попробовать стянуть образ диска через dump/dd по выбору.
3. проверить шлейфики, посмотреть смарт.
4. менять диск, особенно если это на биллинге ;)
Есть полный бекап и этот диск в ред онли, как быстрей всего развернуться на новом диске?
dump / restore
бекапимся как-то так
# dump -0 -f /patch/to/dump.dmp /
Копируем разметку с живого диска (sdb) на новый (sda), создаем файловую стстему
# sfdisk -d /dev/sdb | sfdisk -f /dev/sda
# mkfs.ext4 /dev/sdXX
Монтируемся и разворачиваемся
# mount /dev/sdXX /mnt/
# cd /mnt/; restore -rf /patch/to/dump.dmp
# sync
Правим fstab
# blkid
# /mnt/etc/fstab
# cd /mnt/
Обновляем initramfs, устанавливаем груб
# mount --bind /dev/ /mnt/dev/
# mount --bind /proc/ /mnt/proc/
# mount --bind /sys/ /mnt/sys/
# chroot .
# update-initramfs -u
# grub-install /dev/sdX
выходим с чрута, размонтируемся на всяк sync и пробуем загрузиться
    • Автор: axl72
      Після апгрейду сервера виявилось, що пакет flow-tools, що був у Дебіан 10, зник , починаючи з версії 11. Пошук по офсайту не дав ніяких пояснень. Може шановне панство підкаже, який пакет передбачений на заміну flow-tools для реалізації netflow-коллектора? Чи не гаяти часу і збирати самостійно?..
    • Автор: FOP_Osypenko
      Маємо VPS сервер на Debian 10 і модем MikroTik LHG LTE6. Задача наступна: налаштувати інтернет через VPN тунель.
      На сервер Debian 10 встановив і налаштував WireGuard скриптом: https://github.com/angristan/wireguard-install
      Цим же скриптом згенерував файл налаштувань для клієнта wg0-client-mikrotik.conf:
      [Interface] PrivateKey = yBen7Arcy/jRqB3zqJiPn88IHPCoHYRmRW3wT97D2F0= Address = 10.66.66.2/32,fd42:42:42::2/128 DNS = 94.140.14.14,94.140.15.15 [Peer] PublicKey = 004DOgL44aNB5tWmyoifjiGmi0qBIHdp3Og21EdjUV0= PresharedKey = P8nLh48thuDSvNMJ7XPqMknWp4hpfxE4RUIuf5UBGqQ= Endpoint = 145.239.95.214:53849 AllowedIPs = 0.0.0.0/0,::/0
      Прошивку на Mikrotik оновив до версії 7.1beta5. В цій версії вже вбудована підтримка WireGuarg.
      В головному меню WinBox обираю пункт WireGuard і відкривається таке вікно:
      Створюю новий інтерфейс wiregoard1 з типовими параметрами. Змін ніяких не вношу.
      Далі переходжу на вкладку Peers і там створюю новий тунель. Вписую параметри з клієнтського файлу конфігурації.
      Далі відкриваю вікно Address List і додаю адресу. Параметри знову беру з клієнтського файлу конфігурації.
      Після цих налаштувань нічого не змінюється й інтернет через VPN тунель не йде. Можливо щось не так налаштовую чи не повністю?
    • Автор: axl72
      Здравствуйте , коллеги.
      Поднимаем iptv на линукс-сервере с несколькими разными  DVB картами от TBS.
      Есть одна неприятность. При перезагрузке нумерация DVB адаптеров непредсказуемо меняется. Соответственно конфиги приходится каждый раз подправлять.
      Используем Debian 10.2 Buster  c Systemd.
      Предполагаю, что это происходит из за распараллеливания процесса загрузки и определения оборудования в Systemd.
      Думал о том, что бы использовать udev rules, но из за специфики именования dvd адаптеров не понял как это сделать.
      Наверняка уже кто то сталкивался  с таким поведением, как решили проблему?
      Может отказаться от Systemd и установить SysVinit ? поможет ли?
      Или вообще имеет смысл откатиться на более древний дистрибутив Debian ? И будет ли на нем работать Astra 5.xx
      Предвижу ответы в стиле "Вот возьми , да и проверь сам", именно так мы и сделаем, но хотелось бы минимизировать downtime - сервер уже в продакшене.
    • Автор: Archy_k
      Всем привет.
      Столкнулся с проблемой: не обновился сертификат SSL.
      Попробовал вручную запустить скрипт:
      # /etc/letsencrypt/certbot/certbot-auto renew Creating virtual environment... Installing Python packages... /opt/eff.org/certbot/venv/bin/python: No module named pip.__main__; 'pip' is a package and cannot be directly executed Traceback (most recent call last):   File "/tmp/tmp.qUAUXX5FHZ/pipstrap.py", line 177, in <module>     sys.exit(main())   File "/tmp/tmp.qUAUXX5FHZ/pipstrap.py", line 149, in main     pip_version = StrictVersion(check_output([python, '-m', 'pip', '--version'])   File "/usr/lib/python2.7/subprocess.py", line 544, in check_output     raise CalledProcessError(retcode, cmd, output=output) subprocess.CalledProcessError: Command '['/opt/eff.org/certbot/venv/bin/python', '-m', 'pip', '--version']' returned non-zero exit status 1 И вот какой ответ получаю.
      Подскажите пожалуйста, как с этим справиться...
      Сервер с Debian и nginx
      Заранее спасибо.
    • Автор: Futura
      Имеется тазик на Debian c двумя сетевухами:
      Internet-eth0<NAT<eth1-PPPoE
      Если установить еще одну карточку (пусть будет eth2) c резервным каналом
      как организовать автоматическое переключение при падении основного и корректную работу NAT?
