Posted
? Introducing Our High-Performance OLT Solutions for Next-Gen Networks! ?
Are you ready to elevate your network infrastructure to unparalleled levels of efficiency and speed? Look no further! Our cutting-edge GPON and EPON OLT solutions are here to revolutionize your network operations.
? GPON OLT: With options ranging from 4 to 16 ports, our GPON OLT delivers lightning-fast connectivity and unparalleled reliability. Whether you're managing a small-scale deployment or a large enterprise network, our GPON OLTs offer the scalability and performance you need to stay ahead of the curve.
30000UAH/pcs
Spoiler
? EPON OLT: Experience the power of simplicity with our EPON OLT solutions. Available in 4 and 8 port configurations, our EPON OLTs provide seamless integration and hassle-free management for your network infrastructure. Say goodbye to complexity and hello to streamlined operations!
20000UAH/pcs
Spoiler
Why Choose Our OLT Solutions?
✅ Scalability: Scale your network effortlessly with our versatile OLT solutions, accommodating growing demands without compromising performance. ✅ Reliability: Built to withstand even the most demanding network environments, our OLTs ensure uninterrupted connectivity and minimal downtime. ✅ Ease of Management: Simplify your network operations with intuitive management interfaces and robust monitoring capabilities. ✅ Future-Proof: Stay ahead of technological advancements with our forward-thinking OLT solutions, designed to support future network requirements.
Don't miss out on this opportunity to supercharge your network infrastructure! Contact us today to learn more about our GPON and EPON OLT solutions and take your network to the next level.
Posted
В Китае куча предложений различных OLT с их торговыми марками. Что внутри, как оно в работе, какая система управления - одному Богу известно. У нас как-то всё больше ZTE/Huawei/BDcom разных моделей прижились. Не уверен, что найдутся желающие рисковать деньгами и покупать никому не известные бренды.
Posted
Одна порада, яка допоможе вам знайти потрібну фабрику OEM, перевірте металеву оболонку, дорогий. Це унікально, здебільшого обслуговування OEM стосується лише лицьової панелі, але металева оболонка залишається незмінною. Крім того, існує велика кількість, металева оболонка також буде налаштована.
ZTE, Huawei, вони справді чудові, але без жодної іншої компанії, яка приєднається до цієї сфери, вони монолізують це, ціна та кількість, усе, це залежить від них. Тільки хороша конкуренція, щоб зробити цей світ кращим.
І ми також чудові, наша команда дослідників і розробників працювала над 1U/2U XGSPON OLT за півроку, що, за винятком Huawei, ZTE, ще не розробило це на заводі! Ми пишаємося нашою командою техніків і нашим брендом!
і це було перекладено google, вибачте, якщо деякі слова грубі, якщо це є, і я не маю на увазі це.
Posted
Ми також є постачальником China Mobile, постачаючи їм MAIN ONU для проекту FTTR, і ми також є OEM для відомого корейського бренду. Можливо, ми не такі відомі, як вони, але можемо бути такими ж хорошими, як вони. Ось відгук від нашого клієнта про наш WIFI 6 AX3000 ONU, він пропонує телевізійні послуги з місцевих і взяти 5 одиниць як зразок тесту.
Вибачте, що так багато кажу, просто не хочу викликати непорозумінь, невідомий бренд також заслуговує на можливість вирости. Дякую
Posted
7 часов назад, AlinaQuan сказав:
Питання не в тому відомий бренд чи ні й ви, звичайно, маєте право на просування свого бренду. Проте OLT - складний у керуванні пристрій зі складною системою керування і купою нюансів, які треба враховувати в роботі. Навіть заміна прошивки вже може вимагати корекцій в адмініструванні. Досвід такого адміністрування накопичується роками. Також і весь наявний парк ONU теж якоюсь мірою узгоджений з конкретними моделями OLT і як вони будуть співпрацювати з OLT іншого бренду - невідомо.  І тепер уявіть собі, що треба весь той досвід відкласти вбік і почати вивчення нової невідомої системи з нуля. Хто на
таке наважиться і навіщо це? Звичайно, якщо починати впровадження технологій xPON з нуля, то при цікавих цінах можна розглядати інші варіанти крім відомих ZTE/Huawei/BDcom, проте тоді постає питання підтримки. По відомих брендах завжди можна запитати в спільноти, а по невідомих - в кого питати? У виробника в Китаї? Ще є питання доставлення з Китаю та гарантійного обслуговування при прямому постачанні від виробника. Якось це все виглядає не дуже цікаво. Є ще варіант, що в середині у ваших виробів знаходяться чіпи та прошивки відомих брендів і нічого нового там нема для освоєння, але це нікому невідомо. Короче щось тут не дуже складається.
Posted
8 часов назад, AlinaQuan сказав:
Ви цю модель мали на увазі що на фото? Виглядає цікаво, але що всередині - знову таки невідомо. Навіть ніякого pdf документа нема для ознайомлення з деталями.
Posted
Picture is for our 1U XGSPON ONU, and we also have 2U XGSPON OLT. Yes, we have PDF file for its details, viber me +86 18086327779, you'll be impressed!
Posted
15 hours ago, Baneff said:
问题不在于你是否是知名品牌,你当然有权推广自己的品牌。但是,OLT 是一种复杂的设备,有精密的管理系统和许多需要考虑的细微差别。即使是固件升级,也可能需要对管理进行调整。多年来,我们积累了丰富的管理经验。此外,现有的整个 ONU 机群在某种程度上也与特定型号的 OLT 相协调,它们将如何与其他品牌的 OLT 合作还是个未知数。谁在
为什么敢这么做?当然,如果您从零开始实施 xPON 技术,那么除了众所周知的中兴/华为/BDcom 之外,您还可以考虑其他价格合理的选择,但这样一来,支持问题就出现了。对于知名品牌,您可以随时向社区询问,但对于不知名的品牌,您应该向谁询问呢?中国的制造商?还有从中国发货的问题,以及制造商直接发货的保修服务问题。不知为什么,这一切看起来都不是很有趣。还有一种可能是,你的产品内部有知名品牌的芯片和固件,没有什么新东西可开发,但没有人知道。总之,有些事情并不靠谱。
I'm agree with you, dear. As consumer, you have the right and proper consideration. For OLT, it is a complicated device, many brands start to creat its own system to lock all the clients, but we are not going to do that. About quality, they will know it after test. And we used to OEM OLT/ONU and Switch for other brand before, such as D-link, ZYXEL (you may found our switch similar), and most of our clients are operators, ISP, like China Mobile, Poctenekom, that why we are not famous as other brand. But now, we want to start to bulid our brand now, even it's harder in these time, too much competition, but we still got our strength.
Huawei, ZTE thet are also small company in 1990s, so do we now. But we are not start with zero, we have a great R&D team, they offering 24/7 hours tech support, directly to clients, offering remote control tech support, 1 year warranty and free lifetime tech support! You just contact our sales or technician directly for tech support, no need to ask help from community.
Most of our clients gave us positive feedback about our tech support, a client come to China for suppliers visit and stop by to visit our technician for his great work, it's just a pity that he was in USA for business trip, they didn't meet in person.
And shipment, most of our clients they have trust shipper, we just send goods to his/her shipper directly. I know it's hard to trust a stranger from online, you may meet a cheater, or you may find a trustful person that you two can even be best friend. But that's an interesting part of internation trade, all you have to learn it identify the good suppliers and the bad ones.
BTW, our OLT doesn't setting any restrictions to other brand ONUs and SFPs!
