laffytaffy 84 Posted 2011-02-18 18:02:28 Share Posted 2011-02-18 18:02:28 в течение дня падает NAS Feb 18 19:31:24 gw1 kernel: Fatal trap 12: page fault while in kernel mode Feb 18 19:31:24 gw1 kernel: cpuid = 0; apic id = 00 Feb 18 19:31:24 gw1 kernel: fault virtual address = 0x28 Feb 18 19:31:24 gw1 kernel: fault code = supervisor write data, page not present Feb 18 19:31:24 gw1 kernel: instruction pointer = 0x8:0xffffffff80af1057 Feb 18 19:31:24 gw1 kernel: stack pointer = 0x10:0xffffff803de8dae0 Feb 18 19:31:24 gw1 kernel: frame pointer = 0x10:0xffffff803de8db10 Feb 18 19:31:24 gw1 kernel: code segment = base 0x0, limit 0xfffff, type 0x1b Feb 18 19:31:24 gw1 kernel: = DPL 0, pres 1, long 1, def32 0, gran 1 Feb 18 19:31:24 gw1 kernel: processor eflags = interrupt enabled, resume, IOPL = 0 Feb 18 19:31:24 gw1 kernel: current process = 69 (dummynet) Feb 18 19:31:24 gw1 kernel: trap number = 12 Feb 18 19:31:24 gw1 kernel: panic: page fault Feb 18 19:31:24 gw1 kernel: cpuid = 0 Feb 18 19:31:24 gw1 kernel: Uptime: 1h59m20s Feb 18 19:31:24 gw1 kernel: Physical memory: 2036 MB 7.3-RELEASE CPU: Intel® Core2 Quad CPU Q9300 @ 2.50GHz igb0: <Intel® PRO/1000 Network Connection version - 1.9.5> есть идеи? в пике нагрузка до 400 мегабит pps input (igb0) output packets errs bytes packets errs bytes colls 27933 0 17549339 35141 0 36401589 0 28321 0 18768083 35124 0 35266157 0 29576 0 19515970 37557 0 38769149 0 30251 0 22880248 33325 0 32277713 0 31916 0 25776600 35261 0 33979802 0 33610 0 26394494 38084 0 36832471 0 30658 0 22516381 36474 0 35998845 0 29787 0 21185683 35442 0 35866656 0 28780 0 18422535 39178 0 40795963 0 30159 0 20578956 39864 0 40654908 0 30584 0 22770239 38367 0 38095561 0 28635 0 18549129 38947 0 40238189 0 периодичность ребута хаотичная, может раз в день, а может и раза три за час... Link to post Share on other sites
kvirtu 315 Posted 2011-02-18 18:35:43 Share Posted 2011-02-18 18:35:43 Переходи на mpd+kernel nat - нагрузка на систему намного меньше Link to post Share on other sites
icecybe 35 Posted 2011-02-18 19:19:02 Share Posted 2011-02-18 19:19:02 насколько понял надо обновлять ядро до 8-ой версий. Link to post Share on other sites
laffytaffy 84 Posted 2011-02-18 19:32:18 Author Share Posted 2011-02-18 19:32:18 Переходи на mpd+kernel nat - нагрузка на систему намного меньше я не использую VPN, ip+mac ошибка через раз, то в дамминете, то в irq... и система в ребут Link to post Share on other sites
hellion 4 Posted 2011-02-18 21:09:25 Share Posted 2011-02-18 21:09:25 У меня была похожая проблема с зависанием наса. На Вашем насе не стоит квага? У меня мпд5.4 на фрибсд 7,3 зависало по непонятным причинам. После обновление на фрю 8,1 и мпд5.5, мать серверная, сетвуха интел тоже, и проц ксеон, ната нету, и трафика тоже бывает до 400мбит. Полет нормальный без тюнинга. Обновил и забыл. Link to post Share on other sites
pavlabor 1,977 Posted 2011-02-18 22:50:55 Share Posted 2011-02-18 22:50:55 Посмотри что предшествует падению. У меня подозрение что в 7.3 косяк с обработкой брадкастовых запросов, конкретно от левых ИП блоков на езернет уровне. При чем, брадкастовые арп опросы регистрировались часто, но не всегда машина падала. Но когда падала, то последние записи в логах фигурировали именно левые брадкасты. Кстати под нагрузкой, тоже в районе 400. Перешли на 8.2, все устаканилось. Link to post Share on other sites
laffytaffy 84 Posted 2011-02-18 23:29:11 Author Share Posted 2011-02-18 23:29:11 У меня была похожая проблема с зависанием наса. На Вашем насе не стоит квага? стоит Link to post Share on other sites
laffytaffy 84 Posted 2011-02-18 23:33:22 Author Share Posted 2011-02-18 23:33:22 Посмотри что предшествует падению. У меня подозрение что в 7.3 косяк с обработкой брадкастовых запросов, конкретно от левых ИП блоков на езернет уровне. При чем, брадкастовые арп опросы регистрировались часто, но не всегда машина падала. Но когда падала, то последние записи в логах фигурировали именно левые брадкасты. Кстати под нагрузкой, тоже в районе 400. Перешли на 8.2, все устаканилось. перед падением в логе только сообщение от dhcpd типа Feb 19 01:10:48 gw1 dhcpd: uid lease 10.10.1.248 for client 00:1d:60:20:08:92 is duplicate on 10.10/16 Feb 19 01:13:31 gw1 dhcpd: uid lease 10.10.1.205 for client 1c:bd:b9:b1:81:f3 is duplicate on 10.10/16 Feb 19 01:13:56 gw1 dhcpd: uid lease 10.10.1.249 for client 00:1b:fc:0a:e8:44 is duplicate on 10.10/16 Feb 19 01:15:19 gw1 dhcpd: uid lease 10.10.1.211 for client 00:13:77:65:c2:3f is duplicate on 10.10/16 Feb 19 01:15:48 gw1 dhcpd: uid lease 10.10.1.248 for client 00:1d:60:20:08:92 is duplicate on 10.10/16 Feb 19 01:18:31 gw1 dhcpd: uid lease 10.10.1.205 for client 1c:bd:b9:b1:81:f3 is duplicate on 10.10/16 Feb 19 01:18:57 gw1 dhcpd: uid lease 10.10.1.249 for client 00:1b:fc:0a:e8:44 is duplicate on 10.10/16 Feb 19 01:20:19 gw1 dhcpd: uid lease 10.10.1.211 for client 00:13:77:65:c2:3f is duplicate on 10.10/16 Feb 19 01:20:48 gw1 dhcpd: uid lease 10.10.1.248 for client 00:1d:60:20:08:92 is duplicate on 10.10/16 Feb 19 01:23:31 gw1 dhcpd: uid lease 10.10.1.205 for client 1c:bd:b9:b1:81:f3 is duplicate on 10.10/16 Link to post Share on other sites
laffytaffy 84 Posted 2011-02-18 23:34:33 Author Share Posted 2011-02-18 23:34:33 кстати, для проверки теории про дамминет, отключили вечером шейпер совсем, только нат, посмотрим с какой ошибкой упадет... Link to post Share on other sites
Neelix 33 Posted 2011-02-19 06:51:48 Share Posted 2011-02-19 06:51:48 интернет говорит восновном про ipfw: ouch!, skip past end of rules, denying packet такое есть? Link to post Share on other sites
tech 5 Posted 2011-02-19 07:25:00 Share Posted 2011-02-19 07:25:00 я не использую VPN, ip+mac Возможно ли ипользовать ip+mac без vpn на freeBSD + abills ? Link to post Share on other sites
kvirtu 315 Posted 2011-02-19 08:08:40 Share Posted 2011-02-19 08:08:40 я не использую VPN, ip+mac Возможно ли ипользовать ip+mac без vpn на freeBSD + abills ? Легко, для привязки ip+mac использовать ipguard (интегрируется в abills). Ну а инет раздавать через ipfw. Link to post Share on other sites
hellion 4 Posted 2011-02-19 13:04:34 Share Posted 2011-02-19 13:04:34 У меня была похожая проблема с зависанием наса. На Вашем насе не стоит квага? стоит это напряжно для сервера. а если два канала интеренета то вообще зависать будет. лучше разделить. Link to post Share on other sites
hellion 4 Posted 2011-02-19 13:06:44 Share Posted 2011-02-19 13:06:44 я не использую VPN, ip+mac Возможно ли ипользовать ip+mac без vpn на freeBSD + abills ? Легко, для привязки ip+mac использовать ipguard (интегрируется в abills). Ну а инет раздавать через ipfw. можно на абилсе через ipn роздавать без vpn, как через ipfw pipe так и нг шейпер но тоже с ipfw. читайте на сайте абилса. http://abills.net.ua/wiki/doku.php/abills:docs:manual:ng_car Link to post Share on other sites
laffytaffy 84 Posted 2011-02-19 13:18:49 Author Share Posted 2011-02-19 13:18:49 У меня была похожая проблема с зависанием наса. На Вашем насе не стоит квага? стоит это напряжно для сервера. а если два канала интеренета то вообще зависать будет. лучше разделить. так и есть, 2 канала, в одном "дефолт" в другом "Украина" и "пиринг", отрубили дамминет, ждем когда упадет с другой ошибкой, пока падений нет. В чем напряжность? Квага ресурсов почти не использует на общем фоне. интернет говорит восновном про ipfw: ouch!, skip past end of rules, denying packet такое есть? нет Link to post Share on other sites
adeep 212 Posted 2011-02-19 16:09:51 Share Posted 2011-02-19 16:09:51 это напряжно для сервера. а если два канала интеренета то вообще зависать будет. лучше разделить. кто вам такую глупость сказал? Link to post Share on other sites
hellion 4 Posted 2011-02-19 16:22:29 Share Posted 2011-02-19 16:22:29 это напряжно для сервера. а если два канала интеренета то вообще зависать будет. лучше разделить. кто вам такую глупость сказал? Оно то будет работать если работают каналы, а если упадет Украина, то все приведется ему перемаршрутизировать на дефаулт, при 100впн конектах все корректно будет, проверено, а при 500 впн интерфейсах мпд виснет и система тоже. Лично боролся с этой проблемой, вылечил установкой второго сервера и разделение мпд и бгп, и все сейчас как часы. Link to post Share on other sites
laffytaffy 84 Posted 2011-02-19 16:34:26 Author Share Posted 2011-02-19 16:34:26 Оно то будет работать если работают каналы, а если упадет Украина, то все приведется ему перемаршрутизировать на дефаулт, при 100впн конектах все корректно будет, проверено, а при 500 впн интерфейсах мпд виснет и система тоже. Лично боролся с этой проблемой, вылечил установкой второго сервера и разделение мпд и бгп, и все сейчас как часы. возможно, но VPN не использую, об этом сразу и сказал... Link to post Share on other sites
imroot 19 Posted 2011-02-19 16:59:46 Share Posted 2011-02-19 16:59:46 (edited) мне известно что 7.3 i386 и 7.3 amd64 немножечко разные и при обьемах от 120 мегабит трафика имеют место непонятные вылеты. Поставили amd64 всё как рукой сняло... возможно и Вам поможет ой и ещё свпомнил, как-то с оперативкай были траблы, fatal trap 12 давала Edited 2011-02-19 17:19:30 by imroot Link to post Share on other sites
laffytaffy 84 Posted 2011-02-19 18:36:40 Author Share Posted 2011-02-19 18:36:40 мне известно что 7.3 i386 и 7.3 amd64 немножечко разные amd64 и стоит есть ребут за сутки после отключения дамминета Feb 19 20:25:37 gw1 kernel: Fatal trap 12: page fault while in kernel mode Feb 19 20:25:37 gw1 kernel: cpuid = 0; apic id = 00 Feb 19 20:25:37 gw1 kernel: fault virtual address = 0x0 Feb 19 20:25:37 gw1 kernel: fault code = supervisor read data, page not present Feb 19 20:25:37 gw1 kernel: instruction pointer = 0x8:0xffffffff80473d55 Feb 19 20:25:37 gw1 kernel: stack pointer = 0x10:0xffffff8000136920 Feb 19 20:25:37 gw1 kernel: frame pointer = 0x10:0xffffff0031cf8700 Feb 19 20:25:37 gw1 kernel: code segment = base 0x0, limit 0xfffff, type 0x1b Feb 19 20:25:37 gw1 kernel: = DPL 0, pres 1, long 1, def32 0, gran 1 Feb 19 20:25:37 gw1 kernel: processor eflags = interrupt enabled, resume, IOPL = 0 Feb 19 20:25:37 gw1 kernel: current process = 31 (igb0 que) Feb 19 20:25:37 gw1 kernel: trap number = 12 Feb 19 20:25:37 gw1 kernel: panic: page fault Feb 19 20:25:37 gw1 kernel: cpuid = 0 Feb 19 20:25:37 gw1 kernel: Uptime: 22h54m44s Feb 19 20:25:37 gw1 kernel: Physical memory: 2036 MB если еще раз упадет с такой же ошибкой попробуем обновить до 8.1 Link to post Share on other sites
pavlabor 1,977 Posted 2011-02-19 19:13:34 Share Posted 2011-02-19 19:13:34 мне известно что 7.3 i386 и 7.3 amd64 немножечко разные amd64 и стоит есть ребут за сутки после отключения дамминета Feb 19 20:25:37 gw1 kernel: Fatal trap 12: page fault while in kernel mode Feb 19 20:25:37 gw1 kernel: cpuid = 0; apic id = 00 Feb 19 20:25:37 gw1 kernel: fault virtual address = 0x0 Feb 19 20:25:37 gw1 kernel: fault code = supervisor read data, page not present Feb 19 20:25:37 gw1 kernel: instruction pointer = 0x8:0xffffffff80473d55 Feb 19 20:25:37 gw1 kernel: stack pointer = 0x10:0xffffff8000136920 Feb 19 20:25:37 gw1 kernel: frame pointer = 0x10:0xffffff0031cf8700 Feb 19 20:25:37 gw1 kernel: code segment = base 0x0, limit 0xfffff, type 0x1b Feb 19 20:25:37 gw1 kernel: = DPL 0, pres 1, long 1, def32 0, gran 1 Feb 19 20:25:37 gw1 kernel: processor eflags = interrupt enabled, resume, IOPL = 0 Feb 19 20:25:37 gw1 kernel: current process = 31 (igb0 que) Feb 19 20:25:37 gw1 kernel: trap number = 12 Feb 19 20:25:37 gw1 kernel: panic: page fault Feb 19 20:25:37 gw1 kernel: cpuid = 0 Feb 19 20:25:37 gw1 kernel: Uptime: 22h54m44s Feb 19 20:25:37 gw1 kernel: Physical memory: 2036 MB если еще раз упадет с такой же ошибкой попробуем обновить до 8.1 current process = 31 (igb0 que) Попробуй поставить карточку РТ. ps. Думаю понадежней перейти на восьмерку, мы тестим 8.2, пока без нареканий, а семерка, она какаято чудная от 7.0, до 7.3 Link to post Share on other sites
laffytaffy 84 Posted 2011-02-19 19:23:46 Author Share Posted 2011-02-19 19:23:46 мне известно что 7.3 i386 и 7.3 amd64 немножечко разные amd64 и стоит есть ребут за сутки после отключения дамминета Feb 19 20:25:37 gw1 kernel: Fatal trap 12: page fault while in kernel mode Feb 19 20:25:37 gw1 kernel: cpuid = 0; apic id = 00 Feb 19 20:25:37 gw1 kernel: fault virtual address = 0x0 Feb 19 20:25:37 gw1 kernel: fault code = supervisor read data, page not present Feb 19 20:25:37 gw1 kernel: instruction pointer = 0x8:0xffffffff80473d55 Feb 19 20:25:37 gw1 kernel: stack pointer = 0x10:0xffffff8000136920 Feb 19 20:25:37 gw1 kernel: frame pointer = 0x10:0xffffff0031cf8700 Feb 19 20:25:37 gw1 kernel: code segment = base 0x0, limit 0xfffff, type 0x1b Feb 19 20:25:37 gw1 kernel: = DPL 0, pres 1, long 1, def32 0, gran 1 Feb 19 20:25:37 gw1 kernel: processor eflags = interrupt enabled, resume, IOPL = 0 Feb 19 20:25:37 gw1 kernel: current process = 31 (igb0 que) Feb 19 20:25:37 gw1 kernel: trap number = 12 Feb 19 20:25:37 gw1 kernel: panic: page fault Feb 19 20:25:37 gw1 kernel: cpuid = 0 Feb 19 20:25:37 gw1 kernel: Uptime: 22h54m44s Feb 19 20:25:37 gw1 kernel: Physical memory: 2036 MB если еще раз упадет с такой же ошибкой попробуем обновить до 8.1 current process = 31 (igb0 que) Попробуй поставить карточку РТ. дык это не выход, ставить предыдущее поколение карт, тем более что нет свободной... хочется найти причину.... остался вариант о кол-ве мелких пакетов размеров в 50-100 байт Link to post Share on other sites
pavlabor 1,977 Posted 2011-02-19 19:35:28 Share Posted 2011-02-19 19:35:28 Я когдато с радости накатил 7.1, так она с такой же ошибкой вылетала, при поднятии второй карточки, карточки были брадкомы. Ради интереса, ставил интелы пси-х, и тоже на одном интерфейсе работали, при поднятии второго вешалась, Ставил реалтеки, то же самое, Ставил винт на другие машины, мешал карточки, падала как часы. Плюнул, накатил 8.1 и все забылось. Потом чтото не срослось, нужн было откатиться на 7.3, за два дня, два падения с глухим звисанием, откатился на 8.2, опять нет проблем. И заметил, что железо не важно, конфигурация не важна, нагрузка не важна. То есть причины нет. Просто падает когда ей захочется. Link to post Share on other sites
laffytaffy 84 Posted 2011-02-19 19:47:52 Author Share Posted 2011-02-19 19:47:52 Плюнул, накатил 8.1 и все забылось. видимо этим сегодня ночью и займемся... Link to post Share on other sites
laffytaffy 84 Posted 2011-02-28 10:59:03 Author Share Posted 2011-02-28 10:59:03 обновили до 8.1-RELEASE FreeBSD 8.1-RELEASE #0: Sun Feb 20 17:02:28 EET 2011 root@:/usr/obj/usr/src/sys/GW1 amd64 4 дня "ребутов" не было, все гладко, но сегодня опять что-то непонятное, система виснет без перезагрузки, тупо висит ни на что не реагирует, только кнопка reset... после загрузки в логах чисто до "ступора" input (Total) output packets errs idrops bytes packets errs bytes colls 79586 0 0 83424516 66175 0 54511944 0 70826 0 0 70183816 61302 0 48712723 0 68303 0 0 68300243 58356 0 46195971 0 72591 0 0 73959017 61345 0 48902434 0 72839 0 0 74901501 60994 0 48539391 0 68571 0 0 70988338 56600 0 45816941 0 67263 0 0 67462718 57281 0 45381948 0 72662 0 0 75443880 61208 0 49142041 0 64497 0 0 64985021 54234 0 42896221 0 52296 0 0 51564065 44646 0 35414510 0 56631 0 0 54897734 48962 0 39895923 0 67628 0 0 67007553 57996 0 47182585 0 72153 0 0 74101866 60877 0 48984598 0 62158 0 0 60601173 53730 0 41534317 0 67693 0 0 66948657 57862 0 45194897 0 72156 0 0 71331588 61456 0 47548956 0 Прервано gw1# netstat -w1 -l igb0 input (Total) output packets errs idrops bytes packets errs bytes colls 71600 0 0 69241014 61346 0 48042094 0 75477 0 0 71972522 65001 0 50411770 0 74045 0 0 72446231 62996 0 50295410 0 71111 0 0 68378318 61907 0 49295880 0 76281 0 0 74507232 66225 0 53058864 0 Прервано gw1# netstat -w1 -l igb0 input (Total) output packets errs idrops bytes packets errs bytes colls 73103 0 0 71996330 62971 0 50314810 0 15185 0 0 14117394 11797 0 9846865 0 Link to post Share on other sites
