Mikrotik Backup на Email
Данный скрипт успешно работает на 6.10(powerpc) но не работает на 6.6(mipsbe)
Пожалуйста кто силен в этом скажите в чем дело?
:log info "Starting Backup Script...";
:local sysname [/system identity get name];
:local sysver [/system package get system version];
:log info "Flushing DNS cache...";
/ip dns cache flush;
:delay 2;
:log info "Deleting last Backups...";
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] \
"$sysname-backup-"]]!="nil") do={/file remove $i}};
:delay 2;
:local smtpserv [:resolve "smtpxxxxx.ua"];
:local Eaccount "xxxloginxxx";
:local pass "xxxpassxxx";
:local backupfile ("$sysname-backup-" . \
[:pick [/system clock get date] 7 11] . [:pick [/system \
clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".backup");
:log info "Creating new Full Backup file...";
/system backup save name=$backupfile;
:delay 2;
:log info "Sending Full Backup file via E-mail...";
/tool e-mail send from="<$Eaccount>" to=$Eaccount server=$smtpserv \
port=25 user=$Eaccount password=$pass file=$backupfile \
subject=("$sysname Sm Full Backup (" . [/system clock get date] . ")") \
body=("$sysname full Backup file see in attachment.\nRouterOS version: \
$sysver\nTime and Date stamp: " . [/system clock get time] . " " . \
[/system clock get date]);
:delay 5;
:local exportfile ("$sysname-backup-" . \
clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".rsc");
:log info "Creating new Setup Script file...";
/export file=$exportfile;
:delay 2;
:log info "Sending Setup Script file via E-mail...";
port=587 user=$Eaccount password=$pass file=$exportfile \
subject=("$sysname Setup Script Backup (" . [/system clock get date] . \
")") body=("$sysname Setup Script file see in attachment.\nRouterOS \
version: $sysver\nTime and Date stamp: " . [/system clock get time] . " \
" . [/system clock get date]);
:delay 5;
:log info "All System Backups emailed successfully.\nBackuping completed.";
Ого , помнится мне у меня эдак раз в десять короче ....  краткость сестра таланта однако ...
  В 15.03.2014 в 15:53, prototip сказав:
Ну, мир не идеален....) а пример самого скрипта возможно помог бы решить мою проблему :)
/system backup save name=backup_mikrotik
/tool e-mail send file=backup_mikrotik.backup to="admin@blabla.com" body="backup_mikrotik" subject="$[/system identity get name] $[/system clock get time] $[/system clock get date] Backup"
рабочий простой скрипт где то так ...
У мене реалізовано так
:local day [system clock get date  ];
:local b ([pick $day 4 6].  [pick $day 0 3].[pick $day 7 11]."____Voz" ) ;
:put $b;
/system backup save name=$b;
:delay 5s;
/tool e-mail send server=173.194.70.108 port=587 user=Ваш Юзернейм password=Ваш Пароль file=$b \
to=КудиВідправити@ya.ru    from="ВашЮзернейм@gmail.com" tls=yes subject=server100;
    • Від Karfax
      Всем привет!
      Делал миграцию ubilling на новую машину - установил новыю юбилинг в режиме "миграция с существующего сервера", затем вкатил дамп БД.
      Всё перенеслось нормально, но вот только заметил что Пользователи (Система/Права администраторов) не переносится. В дампе БД даже нет намека на этих пользователей. Скажите, где находится их конфиг?
    • Від Hope
      IPTV потоки для любых проектов  как основные так и бекап.
      UA AZ AM RUS DE TUR BL UK USA Ge Pribaltika  sport all
      писать в личку .
    • Від ixer
      Привіт! Потрібен сервер з онлайн ~ 90% у робочий час. Від 2Тб простору з можливістю в майбутньому розширитись при необхідності. Доступ по FTP, чи інше (що запропонуєте). Під реселінг, тобто я буду надавати доступ до конкретних даних конкретним користувачам, і для цього потрібна можливість створювати користувачів самостійно. Великий трафік в нічний час. Бажано гігабітний канал для швидкого завантаження даних користувачів. Пріоритет - мінімальна ціна та гарантія захисту даних від втрати.
    • Від Oleg2018
      При переносе биллинга на новый сервер сделал восстановоление базы строго по инструкции. Все данные получил. Пользователи работают. Но есть проблема, при создание копии базы через вебинтерфейс создается файл с размер 100 килобайт. База при переносе занимала 18 мегабайт. При проверке целосности базы нашел проблему из представлением op_customers выдает ошибку  #1449 - The user specified as a definer ('root'@'%') does not exist. Кто решал и как эту проблему
    • Від bulgar
      Коллеги, очередной вопрос по BDCOM OLT
      BDCOM(tm) P3608-2TE Software, Version 10.1.0E Build 46085 Copyright by Shanghai Baud Data Communication CO. LTD.
      Даём интернет абонентам по схеме vlan-per-user. Не используем темплейты вовсе, настраиваем все онушки ручками. Конфиг онушки всегда примерно следующего вида:
      interface EPON0/1:4 description Trineva-23 epon onu description Trineva-23 epon onu port 1 ctc vlan mode tag 1104 priority 0 Собственно в чем сабж - при бэкапе конфига посредством костылей (скрипт на копирование по tftp запланированный в cron) скачивается конфиг несколько иного вида:
      interface EPON0/1:4 description Trineva-23 epon onu description Trineva-23 Соответственно, при (НЕ ДАЙ БОГ!) выхода из строя пона и залива бэкапа на другой пон - все онушки придётся настраивать ручками, что при использовании даже 4-х лазерного пона мягко говоря вызывает благоговейный ужас. Есть какой-то ритуальный танец для слива полного актуального конфига? Или, возможно, кто-то мостил ещё более извращенные костыли - буду благодарен за ЛЮБОЙ вариант решения данной проблемы.
