Iptables Per-Connection-Classifier
Заметил в микротике прикольную фичу - PCC.
Позволяет разделить трафик на несколько потоков, причем равномерно.
Очень полезно для overload NAT-а кучи сеток через несколько внешних адресов, например
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=nat-1 passthrough=yes per-connection-classifier=src-address:8/0 \
    src-address=10.100.0.0/16
add action=mark-connection chain=prerouting new-connection-mark=nat-2 passthrough=yes per-connection-classifier=src-address:8/1 \
add action=mark-connection chain=prerouting new-connection-mark=nat-3 passthrough=yes per-connection-classifier=src-address:8/2 \
add action=mark-connection chain=prerouting new-connection-mark=nat-4 passthrough=yes per-connection-classifier=src-address:8/3 \
add action=mark-connection chain=prerouting new-connection-mark=nat-5 passthrough=yes per-connection-classifier=src-address:8/4 \
add action=mark-connection chain=prerouting new-connection-mark=nat-6 passthrough=yes per-connection-classifier=src-address:8/5 \
add action=mark-connection chain=prerouting new-connection-mark=nat-7 passthrough=yes per-connection-classifier=src-address:8/6 \
add action=mark-connection chain=prerouting new-connection-mark=nat-8 passthrough=yes per-connection-classifier=src-address:8/7 \
/ip firewall nat
add action=src-nat chain=srcnat connection-mark=nat-1 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-2 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-3 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-4 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-5 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-6 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-7 out-interface=vlan452 to-addresses=194.44.166.xxx
add action=src-nat chain=srcnat connection-mark=nat-8 out-interface=vlan452 to-addresses=194.44.166.xxx
Есть вопрос - а как реализовать такой же рулсет с помощью iptables?
Відредаговано mr.Scamp
В iptables такие костыли вообще не нужны, делайте обычный snat в диапазон адресов с ключиком persistent или как оно там.
$ipt -t nat -A POSTROUTING -s 172.16.0.128/26 -o vlanXXX -j SNAT --to-source Y.Y.Y.195
$ipt -t nat -A POSTROUTING -s 172.16.0.192/26 -o vlanXXX -j SNAT --to-source Y.Y.Y.196
$ipt -t nat -A POSTROUTING -s 172.16.1.0/26 -o vlanXXX -j SNAT --to-source Y.Y.Y.197
У меня так
SNAT в диапазон адресов не катит, соединения одного и того же юзера размываются по всему диапазону.
Ключик --persistent добавляет хэширование src-dst ip при выборе внешнего адреса, но тоже не то немного, насколько я понимаю, один и тот же юзер будет иметь разные исходящие IP при посещении разных ресурсов.
Пока что присматриваюсь к DNETMAP, штука интересная, но нужно много внешних адресов, по адресу на каждого активного клиента.
У меня так
Тут недостаток в том, что пользователи получают неизменный внешний адрес, что не всегда есть желательно.
Да и при большом количестве внутренних подсетей таким рулсетом неудобно управлять из-за его громоздкости.
Мне вот нравиться решение задачи NAT-а в пул адресов с помощью pf на FreeBSD
nat on vlan210 from 10.200.0.0/16 to any -> 193.106.147.zzz/28 source-hash
А не факт что будут разные, проверьте. И даже если будут - что с того? Распределение равномерное работает как и требовалось.
Тут недостаток
Ну не самый изящный способ. )) Но телега тянет, сети каждый день не добавляются. При большом количестве сетей на баше можно разребать.
Могут быть проблемы с сайтами, где фронт и контент находятся за разными IP-адресами, они требуют, чтобы скачивание/стриминг контента было с того же адреса, откуда был загружен плеер.
Обязательно проверю, кстати.
Насколько я помню при persistent как раз таки по src ip идет хеширование, и проблем не возникает.
Проверил, действительно хэшируется по src-ip, причем даже после ребута внешний адрес остается тем же.
Как все просто оказалось на самом деле ;-) Спасибо всем за советы.
Кстати может кто знает, как в Debian реализовать Per Connection Classifier, а именно балансировку каналов по src адресу? Разбивать трафик по src допустим так - первый ip пошел через isp1, второй ip пошел через isp2, третий снова по isp1 и так далее.
а два дефолта с одинаковым весом не работают?
Не работают. И nexthop тоже не работает корректно. Пример - заходишь в вк, вроде зашло, а музыка не играет, потом во все авторизацию сбрасывает, все потому что последующее соединение идет через другой шлюз.
Надо как-то маркировать и направлять в нужные таблицы.
Вот если бы к этому привязать как-то src адрес, цены не было б.
iptables -t mangle -N NEW_OUT_CONN
iptables -t mangle -A NEW_OUT_CONN -j CONNMARK --set-mark 1
iptables -t mangle -A NEW_OUT_CONN -m statistic --mode random --probability 0.50 -j RETURN
iptables -t mangle -A NEW_OUT_CONN -j CONNMARK --set-mark 2
Відредаговано fet4
нашел релевантную ссылку по теме
http://serverfault.com/questions/237867/iptables-match-for-hashing-ip-addresses
Кстати может кто знает, как в Debian реализовать Per Connection Classifier, а именно балансировку каналов по src адресу? Разбивать трафик по src допустим так - первый ip пошел через isp1, второй ip пошел через isp2, третий снова по isp1 и так далее.[/size]
Решение классическое, через ip rule.
1) создаете 2 таблицы маршрутизации (t1 и t2 к примеру). Как создавать искать лень, ищите. Добавить строчку в /etc/iproute/rt_tables или где-то рядом.
2) Делаете
ip rule add from 192.168.1.0/24 table t1
ip rule add from 192.168.2.0/24 table t2
Классификаторов в rule много, можно задать любые условия. Например по меткам как вы выше делали, хоть это и не тру вей.
3) В таблицы добавляете нужные default GW
ip route add deafult via xx.xx.xx.xx table t1
ip route add deafult via yy.xx.xx.xx table t2
Profit.
Відредаговано KaYot
Не вы не поняли. То что вы написали все есть и работает бомба.
Нужно сбалансировать нагрузку от активных клиентов по двум таблицам допустим 50/50. И не просто сбалансировать, а по src адресу. Чтоб часть ip пошла через первую табличку, вторая часть во вторую. До окончания сесси
Відредаговано fet4
KaYot, ему хочется динамически от нагрузки разбрасывать.
В таком случае нужно прикрутить скрипт к ip-up (pppoe) или к ДХЦП при выдаче ип маркировать или рулить. Но это опять же не динамически по нагрузке.
Хотя бы по очереди пихать то в одну то в другую табличку.
Думаю так и придется, делать костыль. А как лучше реализовать на bash выборку ip, чтобы чередовать таблицы маршрут.?
Відредаговано fet4
ip-down - удление правила из таблички, ip-up - добавление правила в ту табличку, где меньше всего записей...
Так лучше всего. Но, опять же, больше записей не означает бОльшую нагрузку на канал.
ИМХО нормально эту задачу не решить.
Если речь об аналоге микротиковских правил, то тут уже ответили. Если о динамически по нагрузке, то нормально никак. Нагрузка сама по себе динамическая.
    • Від viktorrc17
      Lan 192.168.0.1
      Lan 192.168.1.1
    • Від defence_k
    • Від Drader
    • Від valexa
      Всех преветствую. Куплю, возможно какой то аналог микротик, предлогайте рассмотрю все варианты. Всем мира.
    • Від x-net
