Нет интернета у абонов
Здравствуйте, господа форумчане. Помогите пожалуйста решить проблемку с убилингом:
У абонов нет интернета на новой подсети. Айпи выдаются, шлюз пингуется, интернета нет.
Система ubuntu 18.04
19 часов назад, vovvw сказал:
DNS для новой подсети прописан?
В 5/8/2019 в 17:29, vovvw сказал:
Personas que intentaron ayudar, gracias) no había una regla en el firewall para la nueva red)
Hi, I have the same problem
Can someone help me how you set up the firewall rules I know there are numerical tables
  But I don't understand how he set it up
Can someone give me an example of how to do so that for example customers by 172.16.1.0/24 have access to the internet and when they have disconnected in uniling lose the internet connection
use freedBSD 11.2
В 11.08.2019 в 07:51, ilcergio сказал:
use freedBSD 11.2
No matter which version you are using. For example:
# Network interfaces
LAN_IF="em1"
WAN_IF="em0"
# Path to network sensor Netflow (Ubilling white IP must be here)
/usr/local/sbin/softflowd -i ${LAN_IF} -n 1.2.3.4:42111
# Firewall launch command
FwCMD="/sbin/ipfw -q"
${FwCMD} -f flush
${FwCMD} -f pipe flush
${FwCMD} -f queue flush
${FwCMD} table all flush
# Interfaces setup
LAN_IF="re2"
WAN_IF="re0"
# Networks define
${FwCMD} table 2 add 192.168.0.0/20
${FwCMD} table 2 add 192.168.30.0/23
${FwCMD} table 2 add 192.168.40.0/23
${FwCMD} table 9 add 1.2.3.4/32
# NAT
${FwCMD} nat 1 config log if ${WAN_IF} reset same_ports
${FwCMD} add 6000 nat 1 ip from table\(2\) to not table\(9\) out xmit ${WAN_IF}
${FwCMD} add 6001 nat 1 ip from any to me in recv ${WAN_IF}
# Shaper - table 4 download speed, table 3 - upload speed
${FwCMD} add 12001 pipe tablearg ip from any to table\(4\) via ${LAN_IF} out
${FwCMD} add 12000 pipe tablearg ip from table\(3\) to any via ${LAN_IF} in
# Default block policy
${FwCMD} add 65533 deny all from table\(2\) to any via ${LAN_IF}
${FwCMD} add 65534 deny all from any to table\(2\) via ${LAN_IF}
#${FwCMD} add 65535 allow all from any to any
# Access to default router
${FwCMD} add 101 allow icmp from any to any via ${LAN_IF}
${FwCMD} add 101 allow all from 192.168.0.1 to any
${FwCMD} add 101 allow all from any to 192.168.0.1
${FwCMD} add 101 allow all from 192.168.30.1 to any
${FwCMD} add 101 allow all from any to 192.168.30.1
${FwCMD} add 101 allow all from 192.168.40.1 to any
${FwCMD} add 101 allow all from any to 192.168.40.1
# Google DNS
${FwCMD} add 4 allow ip from table\(2\) to 8.8.8.8 dst-port 53 via ${LAN_IF}
${FwCMD} add 4 allow ip from table\(2\) to 8.8.4.4 dst-port 53 via ${LAN_IF}
${FwCMD} add 4 allow ip from 8.8.8.8 to table\(2\) src-port 53 via ${LAN_IF}
${FwCMD} add 4 allow ip from 8.8.4.4 to table\(2\) src-port 53 via ${LAN_IF}
# Unknown users redirect
${FwCMD} add 5 fwd 127.0.0.1,80 ip from 172.32.0.0/20 to not me dst-port 80
# Access to my web
${FwCMD} add 4 allow ip from table\(2\) to me dst-port 80
${FwCMD} add 4 allow ip from me to table\(2\) src-port 80
Something like that...
Изменено пользователем ISK
25 минут назад, ISK сказал:
LAN_IF="em1"
WAN_IF="em0"
где правильно?
# Interfaces setup
LAN_IF="re2"
WAN_IF="re0"
также нужен конфиг
rc.conf
10 минут назад, l1ght сказал:
он второй раз переопределил переменные, так что то что последнее
это понятно, вопрос какие сетевые установлены? поэтому и "запросил" конфиг rc.conf.
В 15.08.2019 в 16:04, a_n_h сказал:
где правильно?
Сорри, первые 2 строки должны были быть или закомменчены или вообще не указаны, но переопределение работает же:) Сетевые да, реалтековские. Но для биллингового сервака при наличии 2-х внешних NAS на интеловских сетевухах пока сойдёт?
В 15/8/2019 в 8:37, ISK сказал:
No importa qué versión estés usando. Por ejemplo:
# Interfaces de red
LAN_IF = "em1"
WAN_IF = "em0"
# Ruta al sensor de red Netflow (Ubilling IP blanca debe estar aquí)
/ usr / local / sbin / softflowd -i $ {LAN_IF} -n 1.2.3.4:42111
# Comando de inicio del cortafuegos
FwCMD = "/ sbin / ipfw -q"
$ {FwCMD} -f flush
$ {FwCMD} -f pipe flush
$ {FwCMD} -f queue flush
$ {FwCMD} table all flush
# Configuración de interfaces
LAN_IF = "re2"
WAN_IF = "re0"
# Las redes definen
$ {FwCMD} tabla 2 agregar 192.168.0.0/20
$ {FwCMD} tabla 2 agregar 192.168.30.0/23
$ {FwCMD} tabla 2 agregar 192.168.40.0/23
$ {FwCMD} tabla 9 agregar 1.2.3.4/ 32
# NAT
$ {FwCMD} registro de configuración nat 1 si $ {WAN_IF} restablece same_ports
$ {FwCMD} agrega 6000 nat 1 ip de la tabla \ (2 \) a la tabla \ (9 \) fuera xmit $ {WAN_IF}
$ {FwCMD } agregue 6001 nat 1 ip de any a mí en recv $ {WAN_IF}
# Shaper - velocidad de descarga de la tabla 4, tabla 3 - velocidad de carga
$ {FwCMD} agregue 12001 pipearar ip de cualquiera a la tabla \ (4 \) a través de $ {LAN_IF} out
$ {FwCMD} agregue 12000 pipearar ip de la tabla \ ( 3 \) a cualquier vía $ {LAN_IF} en
# Política de bloqueo predeterminada
$ {FwCMD} agregue 65533 negar todo de la tabla \ (2 \) a cualquiera a través de $ {LAN_IF}
$ {FwCMD} agregue 65534 negar todo de cualquier a la tabla \ (2 \) a través de $ {LAN_IF}
# $ {FwCMD} agregar 65535 permitir todo de cualquiera a cualquiera
# Acceso al enrutador predeterminado
$ {FwCMD} agregar 101 permitir icmp de cualquiera a cualquiera a través de $ {LAN_IF}
$ {FwCMD} agregar 101 permitir todo de 192.168.0.1 a cualquier
$ {FwCMD} agregar 101 permitir todo de cualquiera a 192.168.0.1
$ {FwCMD} agregar 101 permitir todo de cualquiera a 192.168.30.1 a cualquier
$ {FwCMD} agregar 101 permitir todo de cualquiera a 192.168.40.1
# Google DNS
$ {FwCMD} agregar 4 permitir ip de la tabla \ (2 \) a 8.8.4.4 8st.8 puerto dst-port 53 a través de $ {LAN_IF}
$ {FwCMD} agregar 4 permitir ip de la tabla \ (2 \) a 8.8.4.4 dst-port 53 a través de $ {LAN_IF}
$ {FwCMD} add 4 allow ip de 8.8.8.8 a la tabla \ (2 \) src-port 53 a través de $ {LAN_IF}
$ {FwCMD} add 4 allow ip de 8.8.4.4 a table \ (2 \) src-port 53 a través de $ {LAN_IF}
# Los usuarios desconocidos redirigen
$ {FwCMD} agregan 5 fwd 127.0.0.1,80 ip desde 172.32.0.0/20 a no me dst-port 80
# Acceso a mi web
ip from me to table \ (2 \) src-port 80
Algo asi ...
gracias  Thank you
  • 3 years later...
    • Автор: ProstoName
    • Автор: ppv
    • Автор: camchatix
      Привіт!
    • Автор: camchatix
      Добрий день,
    • Автор: grach_witch_cheese
      Вітаю, колеги!
      Маю наступну схему:
      Питання:
