Shuher 216 Опубликовано: 2015-09-03 07:29:23 Share Опубликовано: 2015-09-03 07:29:23 Доброго дня всем! Нужно поднять lacp между cisco 3550 и екстримом interface Port-channel1 description LACP p2+3 switchport trunk encapsulation dot1q switchport trunk allowed vlan 1416 switchport mode trunk interface GigabitEthernet0/2 description LN switchport mode dynamic desirable no cdp enable channel-protocol lacp channel-group 1 mode active И вот результат не поднялось : Switch#show interfaces port-channel 1 Port-channel1 is down, line protocol is down (notconnect) Hardware is EtherChannel, address is 0011.2196.fb82 (bia 0011.2196.fb82) Description: LACP p2+3 MTU 1546 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 0/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed, media type is unknown input flow-control is off, output flow-control is off ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:10:06, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 47990 packets input, 6965412 bytes, 0 no buffer Received 2 broadcasts (0 multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 2 multicast, 0 pause input 0 input packets with dribble condition detected 11 packets output, 896 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out Ссылка на сообщение Поделиться на других сайтах
KaYot 3 738 Опубліковано: 2015-09-03 07:53:07 Share Опубліковано: 2015-09-03 07:53:07 А no shutdown делали для портов и Po1? А Po1 настраивали после портов? Ссылка на сообщение Поделиться на других сайтах
tkapluk 926 Опубліковано: 2015-09-03 08:12:35 Share Опубліковано: 2015-09-03 08:12:35 (відредаговано) У меня на 3560 так работает: interface Port-channel1 description SWJ-R6 switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate ! interface GigabitEthernet0/2 description SWJ-R6:ge-0/0/3 switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate channel-group 1 mode active ! interface GigabitEthernet0/24 description SWJ-R6:ge0/0/17 switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate channel-group 1 mode active Cisco – Juniper LACP Відредаговано 2015-09-04 05:16:44 tkapluk Ссылка на сообщение Поделиться на других сайтах
Shuher 216 Опубліковано: 2015-09-03 08:17:52 Автор Share Опубліковано: 2015-09-03 08:17:52 Все заработало когда на Gi 0/2 прописал vlanы, всем спасибо Ссылка на сообщение Поделиться на других сайтах
KaYot 3 738 Опубліковано: 2015-09-03 08:33:16 Share Опубліковано: 2015-09-03 08:33:16 (відредаговано) Неверное решение. на Gi надо прописывать только channel-group, а все остальное уже после в Po. А в идеале - сперва в Gi, потом в Po. На всякий случай. Вероятно ты вначале сделать интерфейс portchannel1, а потом уже настроил эзеры вначале. Відредаговано 2015-09-03 08:34:08 KaYot Ссылка на сообщение Поделиться на других сайтах
Ajar 94 Опубліковано: 2015-09-03 09:23:36 Share Опубліковано: 2015-09-03 09:23:36 настройки портов делаем копи пастом 1:1 , на экстриме включите balance L3-L4 , в принципе циска-экстрим нормально работают в ласпе Ссылка на сообщение Поделиться на других сайтах
muff 117 Опубліковано: 2015-09-03 20:41:03 Share Опубліковано: 2015-09-03 20:41:03 Может кому-то еще пригодится. Настройка LACP. Ссылка на сообщение Поделиться на других сайтах
Shuher 216 Опубліковано: 2015-09-03 20:54:29 Автор Share Опубліковано: 2015-09-03 20:54:29 Неверное решение. на Gi надо прописывать только channel-group, а все остальное уже после в Po. А в идеале - сперва в Gi, потом в Po. На всякий случай. Вероятно ты вначале сделать интерфейс portchannel1, а потом уже настроил эзеры вначале. Ты хочеш сказать что от перемены мест слогаемыми сумма меняется? В моем идеале уже все работает! Спасибо ТЕБЕ за внимание. Всем спасибо, заработало. На интерфейсы прописал вланы Ссылка на сообщение Поделиться на других сайтах
KaYot 3 738 Опубліковано: 2015-09-03 21:00:47 Share Опубліковано: 2015-09-03 21:00:47 (відредаговано) Неверное решение. на Gi надо прописывать только channel-group, а все остальное уже после в Po. А в идеале - сперва в Gi, потом в Po. На всякий случай. Вероятно ты вначале сделать интерфейс portchannel1, а потом уже настроил эзеры вначале. Ты хочеш сказать что от перемены мест слогаемыми сумма меняется? В моем идеале уже все работает! Спасибо ТЕБЕ за внимание. Да, у циски от перемены мест слагаемых сумма меняется. В данном случае порядок жизненно важен, при добавлении интерфейсов в port-channel уже после создания интерфейса Po вланы(а так же любые другие настройки заданные в Po) не будут активированы. Відредаговано 2015-09-03 21:04:05 KaYot Ссылка на сообщение Поделиться на других сайтах
